roll cages
roll cages
hi all again,just a quick question, can a 6 point bolt in cage be welded in stead, its just the bolt in is £100 cheaper, thanks for any help,although i dont see why it cant, i would rather ask your advice just to make sure,
rich
Re: roll cages
You should really check with the relevent racing authority for the sport you plan to use it in.bones wrote:hi all again,just a quick question, can a 6 point bolt in cage be welded in stead, its just the bolt in is £100 cheaper, thanks for any help,although i dont see why it cant, i would rather ask your advice just to make sure,rich
If it is just for road use and cool looks, you might want to consider what happens to your head when you whack it against a roll cage with no helmet on.
Companies sometimes won't insure stuff with a rollcage, because it says 'competition' and because of the steel bar/head interface thing. Worth checking out with yer insurers.
edit - PS - with a modified Mk1 yr prob eligible for the NSRA insurance scheme, which rocks. Must be pre-72 RWD & 'modified'. The scheme doesn't worry about cages, nitrous, engine sizes, etc. Just don't bother with the NSRA forum though...
I have my Morris hot rod insured with the NSRA scheme. For an agreed £6000 value, and a 3.5 Rover V8, unlimited mileage, fully comp, WITH breakdown insurance, I pay £220 a year.Alley Kat wrote:Companies sometimes won't insure stuff with a rollcage, because it says 'competition' and because of the steel bar/head interface thing. Worth checking out with yer insurers.
You have to send them full spec, info and piccies of your car and get an 'estimate' of the value first.
I hear what you're saying about the NSRA forum, a cat fight most of the time, but their 'tech' forum is worth a look for useful info.
hi ya, im a member of the nasc, and i insure all my cars with roadsure. looking at some diagrams of weld-in cages and bolt-in i take there isnt to much of a problem doing what i asked, but now another question, which ones is best a safety devices, omp, or a sparco roll cage, also i cant find any info on the dia of the tubing, anyone help with this. and although i think it should be ok to weld up a bolt in cage,the people on here have far more knowledge of cars than me, so is it yes or a no, all the best and thanks for any replies.
rich.
Rich, There is no reason why you cant weld a bolt in cage, My cage is bolted onto welded in plates with retained nuts, so at least I have the option of removing the cage if I need to do some work, A fella to talk to is Gary at Retro, used to be into Drag racing, but now builds mostly old skool fords for road and track, and may have a old cage knocking about, he does do nice work if you need bits made, and I dont think he is too far from you.
Ian,
http://www.classicrsfords.co.uk/retromotorsport.htm
Ian,
ok i have another question, i need to put some extra bars in ,is it ok to use square tubing ,it would be used behind the seats, for a tunnel brace and rear strut brace and lower back stays, i know i can buy roll cage tubing at £16 a metre, but the sqaure tubing i can get free, any advice welcome,
Rich
