Fracturing Radiator
ppyvabw
Fracturing Radiator
Post by ppyvabw »
The top hose joint on my radiator keeps fracturing and leaking. Last time I fixed it, it lasted 6 months, but it has fractured again and I noticed it this morning. Theres plenty of hose so i dont think its engine movement. I think its caused by cooling and heating repeatedly.
Any suggestions?
could it be because of the plenty hose that its cracking? Might be setting up a high frequency vibration thats cracking the joint.
ppyvabw
Post by ppyvabw »
Well, i say plenty. Its about a foot in length in total with a solid piece in the middle for a filler nut.
Ile try and get my webcam out the window tomorrow and take a pic.
Might be caused by excessive pressure in the rad causing the metal to flex. I had a Series Land Rover rad that used to crack on one of the corners. I kept soldering it, but after a few cycles it would crack the solder again.
Return to “Cooling Area”
