MGB Rear Disc Kit
tetlow
MGB Rear Disc Kit
Post by tetlow »
Does anyone know a UK company that sells a rear disc kit for the std Tube MGB axle please? :D
Regards
1973 MGBGT
1975 MGB V8
I thought I could see the light at the end of the tunnel but it turns out it was a train comming!!
kev_the_mole
Post by kev_the_mole »
Dave,
here http://www.mgcars.org.uk/v8_conversions ... rdisc.html
shows you how to do it yourself but I've never heard of a kit.
Alternatively a reasonable number of Jag IRS conversions have been done and come with discs as standard.
tetlow
Post by tetlow »
Thanks Ian :D
JC.
Post by JC. »
What about Hoyle IRS?
Comes as a complete kit and just bolts on to the original suspension mounts.
Only problem is you need at least 15 inch wheels although John is currently working on a mod so that you can use original factory V8 wheels.
Image -JC.
mgbloke
Post by mgbloke »
Ive just upgraded my solid rear discs on the MGB V8 to vented so I have a rear disc kit up for grabs.
I used rover 800 rear discs , Custom brackets, cosworth/sierra rear calipers. To make it easier I had to fit a 10mm spacer between the hub and disc so had 15x7 compomotive wheels made to fit with the right offset.
Im open to offers for the whole kit inc a pair of wheels but except the handbrake cable.
My new setup hs 11inch vented wilwood discs on ally bells with cossy 4x4 calipers.
Mark
