Combustion chamber porting? Worth or not?
kokkolanpoika
Hi..
What are you think about Rover v8 combustion chamber porting?
My heads are 4,6 10 bolt head, and i´m thinking to modify this combustion chamber "valve" wall area.. Slightly rounded??
And next to skim head to get correct CR ratio..
Has anyone any experience/pick?
Timo
I am unsure exactly what you intend to do but it sounds like blending and smoothing the area around the valves, a small amount would not do any harm as far as I can see, but do not take out anything that will reduce the extreamly limited squish area on that head, I am unsure that you will actually gain anything you can measure either but if it looks better it can be quite satisfying to do. The best thing to change on the rover combustion chamber is to try and increase the squish area by adding metal in the area of the plug to make a kidney shaped combustion chamber which is also more compact. I also think however that there is too much material to add for it to be practical. What you should be aiming at is a chamber like the Chevy LS1,Sb2.2(if you can change the valve angles, or the brodix/AFR/RHS designs for the small block Chevys or the later ford 302 heads, all good chamber shapes. but a long way from the rover.
Best of luck
Best of luck
If you are running high comp ratio or a bit shot of gas it wont hurt to try and gently polish the face of the combustion chamber. But beware of taking material away so you dont alter the chamber cc.
I just use very fine wet and dry paper with oil to polish my chambers a little. Then finish with a buffer brush and metal polish to finish the chambers off.
Detonation is my enemy!!
- ihatesissycars
- ihatesissycars
around about 9.9:1 depends if you do actually have 9.35:1 heads are usually 37cc or more not the 36 they are meant to be and the volume on top of the pistons are usually larger than they should be too. I have seen them as low as 9-9.1 never actually seen one on or above the 9.35 in standard form. I guess the tolerances are all on the low CR side. If you go this route remember and get the inlet skimmed too or it wont fit anymore with a 1mm head skim. Probably best to skim the inlet on the heads rather than the manifold. If you want more you can deck the block by about .5mm ish anymore than that and you have to start checking piston to head clearance
- ihatesissycars
goodsy1968
I should also add be very careful with valve piston clearance. There is a very high chance you need pockets when you skim stuff that much even with a moderate cam. Course you pocket your pistons and you bugger up your new found high compression so you need to skim more. Then you need to top your pistons to stop them hitting the heads f you take it off the block.
goodsy or anybody even, do you know how thick the face of the heads are? I think to get rover heads down to 6cc will need a huge amount taken off them. Or do you mean welding them up as well?
goodsy1968
- ihatesissycars
Well my heads are (stage 2) from V8 Developments and have had the chambers altered and the faces skimmed and i believe they're about 37cc already so i guess i'd need to establish how much has been taken off already and work out what is left that is available to remove.
Or start again with some 28cc heads to get my c/r up KERRRCHING!
It always comes down to not enough sodding money though eh!
Last edited by ihatesissycars on Thu Jan 18, 2007 10:39 am, edited 1 time in total.
