Prop Shaft - Single or 2 Piece
r2d2hp
Post by r2d2hp »
Need to get a replacement propshaft and was wondering if I should just have my 2 piece modified or have a single piece made up
Anyone know the the Pro's and con's of each?
i stayed with my 2 piece mate and had no probs,
propshaft services made me a new 2 piece one in feltham,
Re: Prop Shaft - Single or 2 Piece
r2d2hp wrote:Need to get a replacement propshaft and was wondering if I should just have my 2 piece modified or have a single piece made up
What car, what drivetrain, what are youre requirements ?
How much room in the tunnel ? Fixed rear diff, or one that moves ?
There are lots of things that dictate what can be used.
r2d2hp
Post by r2d2hp »
Thanks Tony
Stevie, its a Mk1 V8 Capri, T5 box, leaf springs and Atlas Axle. Only used on Road and maybe track days.
There is already a slip yoke at the front...so that allows a 1 piece ok.
Diff ratio ? potential shaft speeds ?
Again...long 1 piece shafts have rotational speed limitations. Although also have the potential to be stronger, and of course lighter than a 2 piece.
The longer the shaft...the slower it can spin before trouble.
I'd say you'd be fine either way though. A 1 piece could likely be cheaper and stronger, hence some people favour them.
In cars with potential for high propshaft speeds...and a very long overall length. Sometimes a 2 piece is the only option, aside from carbon fibre etc.
In my case...for all these reasons, a 2 piece was my only option
r2d2hp
Post by r2d2hp »
Hi Stevie
Its a 3.09 diff, prop length is 114.5 cm, 15"wheels, tyres 245*45 and engine is currently around 320 bhp on 3psi boost
So if the tunnel will allow shall I go for single piece prop?
A 45" long steel shaft, 2.5" diameter can safely spin to about 8800rpm....
That's enough for 200mph on your setup.
2.0" steel would drop that to 7000rpm shaft speed, circa 160mph
2.25" steel 8000rpm, circa 180mph
That's actual tube length as far as I am aware...so if its 45" overall...flange to box, then potential speeds could be higher.
Critical speed.
http://en.wikipedia.org/wiki/Critical_speed
r2d2hp
Post by r2d2hp »
Many thanks for the reply Stevie
r2d2hp
Post by r2d2hp »
Been out to me shed and found a 2.5 and 3" dia single prop so just need to get shortened and correct yoke fitted.
45" was from Diff flange to end of tail shaft so the tube is about 39" long so will go with 2.5" dia shaft.
Just need a yoke to fit TVR T5 box, anyone have one spare?
