Flywheel for 3.9
totusbt
Flywheel for 3.9
Post by totusbt »
I have a 3.9 RR engine I am about to put it into a kitcar with a LT77 gearbox, I have a flywheel but it seems very heavy!
out of all the rover V8 flywheels which is the lightest, P6, SDI, RR manual etc
Brian
I would avoid a P6 one on grounds of age, SD1 should be the lighter than the RR, don't be tempted to lighten a RR one, they can explode if lightened which can spoil your transmission tunnel :D . If you want a light flywheel I would buy an aftermarket one.
