twin vapouriser into 4 s.u.s?
chuggernought
Post by chuggernought »
i have an omvl twin vapouriser, the one thats supposed to be the mutts nuts, it appears to have two gas ports to the carbs, one of which is capped off with a rubber bung.
can i use both these ports? i have a boxer inlet with 4 s.u.s, so i am hoping each port will supply 2 s.u.s.
any one else tried to gas 4 s.u.s?
Rossco
Moderator Gold
Moderator Gold
Post by Rossco »
You can use both outlets. This is usually only done on large capacity engines though.
You may find that setting the mixture correctly is far more difficult.
Return to “LPG Section”
