Valve springs
topcatcustom
Valve springs
Post by topcatcustom »
Nigel at UK blowers has told me that I should be ok with single heavy duty valve springs but I just thought I would get a second opinion from you guys!
Its a 4.0 with real steel blower cam (which recommends double springs) and 4-71 blower atop, and rhodes lifters.
Double springs will end up costing about a hundred quid more by the time I buy suitable retainers and have machining done on the seats- but I could spend that on repair parts if singles prove not to be up to the job!
I want to order the parts on monday so everyones advice is welcomed!!!
TC
chodjinn
Post by chodjinn »
The question is TC, for the sake of an extra ton, do you really want to risk breaking a single spring and having a valve or two having a word with one of your pistons?? I would fit double springs no matter what, just for peace of mind.
ukblowers
Post by ukblowers »
Valve springs should be dictated by cam choice..........7 psi of boost behind them doesn't make a blind bit of difference. You didn't mention the real steel blower cam.........go with the recommended double springs.
Return to “Forced Induction”
