Temp Gauge out of range
I drove my Land rover down to my mates garage today for a few final bits of work before the MOT and finally ran it up to temp correctly (checked with external temp gauges.
Basically my Temp Gauge reads in the red when the engines up to temp... Can I put a resistor in line to bring it into the correct range or something?
Sorry should have given more detail. The sender is brand new. The gauge is not, however was working previously.
They are most likely mismatched items as its a gauge for a 2.25. Ideally I don't want to change the gauge as I will be doing a long trip in the next few days and would like to keep an eye on the temp!
Cooling system is in good order, the fan (when switched on) cools the engine nicely enough. Plan is to switch it on un traffic and leave it off unless on a big hill.. any other ideas welcome
The easiest way to fix it is to match the sender & gauge.
Otherwise you need to find out if the sender is too low or too high resistance, as the compensation circuit is different for each one (resistor in series for too low a resistance, and in parallel for too high).
Yup this would mean fitting an aux gauge though I guess. That is something I plan to do next year (full set of gauges).ChrisJC wrote:The easiest way to fix it is to match the sender & gauge.
Anyhow I have a few boards knocking around from some arcade machines tha run 12v.. So will have a bit of trial and error and see ehre that gets me!
A sender from a 225 petrol may be the cheapest option, At least the temp sender is easy to get atChrisJC wrote:Sorry, my mistake!, I forgot yours was a series!
Yes, stage 1 or 101FC are worth a try.
I think I would try to fit the 4-cyl temp sender though as the best solution.
Bit late here i know but i fitted a v8 to my 2.25 engined 90 and was pleasantly surprised to find that according to microcat the gauge used was the same on both engines, i just had to spend a few quid on a new v8 sender.
I don't know if this applies to the Series, but guess it would. Like Chris said, Stage1 or 101 were both around at the same time and probably used the same gauges...
Even if the gauge doesnt read correctly, as long as you verify the temp is correct by some other means and you get used to where the needle usually sits then you'll know when things are going wonky. My old sender on the 2.25 was wrong and it always looked like it was stone cold!
1974 Rover 3500s
1984 3.5 90
1959 2.25 series 2
1984 3.5 90
1959 2.25 series 2
Im happy the engine is running at the right temp and the fan cools it when switche don.. but with the engine at normal temp the gauge i way in the red, meaning if it started to over heat it wouldn't have far to climb!Quagmire wrote:
-JC.
