air intake
bodger
air intake
Post by bodger »
as you can see there's not a lot of room for a air box , i was wondering if fitting a long hose of the same diameter as the as the mixer/AFM would help breathing ?
JC.
Post by JC. »
Apparently extending the length of the inlet tract does help to boost power.
Have a look at this...
http://www.mgcars.org.uk/peterburgess/flugelhorn.html
Image -JC.
That tells you that there's much more science to an inlet tract than meets the eye.
I always think that engine / car designers do actually know what they are doing!
bodger
Post by bodger »
JC. wrote:Apparently extending the length of the inlet tract does help to boost power.
very good , cheeky bugger nicking my bodge i use plastic gutter fittings , they fit perfectly but not quite that long
