oil pressure switch
bodger
oil pressure switch
Post by bodger »
which one to go for ?
intermotor 50611 3-5 psi
or
intermotor 50600 5.8-10psi
satancom
Re: oil pressure switch
Post by satancom »
bodger wrote:which one to go for ?
or
Quite apt as mines gone too :)
I would go for the lower pressure one as I don't know many RV8's that hold 10PSI when hot at idle in drive.
bodger
Post by bodger »
looks like in depends on how old the engine is :
http://partfinder.smpeurope.com/index.h ... alue=13421
http://partfinder.smpeurope.com/index.h ... alue=27500
mine started off life as a 90/110 landie lump so i'm going for the 50600
bodger
Post by bodger »
fitted an intermotor 50600 and it works fine .. about £10 roughly
rob b
Post by rob b »
My oil light has stopped working too :( is there any way to check the bulb and wiring is OK before replacing the oil switch as it isn't very old and I would be surprised if it had failed again, no light when ignition is on but im sure the light flickered for a nano second whilst the starter was cranked. Any ideas?
Mk3 Toyota Hilux 4x4 with 3.9efi RV8 now with Marlin Crawler Transmission
bodger
Post by bodger »
take the connector off the pressure switch and put it to earth ..if the bulb lights it the switch ..
because thats all the switch does ..when no oil pressure the switch just puts the wire to earth so the bulb lights and when you have pressure it breaks the connection ..light off
rob b
Post by rob b »
cool just tried that and light is OK, must be the switch dammit, is not very old at all. crappo brit part probably. Thanks for the tip :D
