RV8 Oil Change Procedure - Question 2
IanT
Post by IanT »
Q2:
I know you all recommend 20w50 - Valvoline or Duckhams.
I heard a rumour that the 'Classic' Oil that Halfords sell in gallon tins is actually Duckhams. Anybody know?
Q1: This is going to sound pretty basic.. but.. do you take any special precautions for an oil change on a Rover V8?
I'm just wondering about lifters draining, or oil pump unpriming itself..
Hints or tips?
Drain the oil as normal.
But fill your new filter up with oil BEFORE removing the old one, then quickly swap them over.
JSF55
Post by JSF55 »
I've left mine drain down overnight and not had a problem with the pump emptying, i think it's more to do with getting an empty pump to prime from new, always fill the filter if u can saves any air running round the bearings and lifters, john
landybob_v8
Post by landybob_v8 »
i always drop the sump and let it drain empty then do the filter and re fill the oil
i was always taught the 20 minuite rule for full drain filter swap and refill
apartently anything after 20 mins its starts draining from the pump
but if you change the filter while you still have sump oil, and top up the filter fully before fitting it (fill until no bubbles come out from the filter) then refit and then drain and refill the sump you wont have any problems
if you do loose oil pressure shouldnt be any problem whipping under to grab off the pump base and repack it but i cant see it happening
v8's everywhere at least the one in the spare bedrooms gone now
mrs happy again
Stephen Leckie
Oil change.
Post by Stephen Leckie »
As above, drain sump, refill sump. Then unscrew filter, fill with oil, attach. If you drain the sump, then unscrew the filter, then you run the risk of syphoning the pump dry - especially if it is a bit worn. Pain in the backside when a ten minute job becomes a two hour job, and you know that there is vaseline inside your engine. I have 5 V8' Landies, same oil, mineral 15/40. Same stuff goes in diesel Landies. Buy it by the 25 litre can. Most motor factors, or garages.
PS Landybob, great site. How do you start such a site?
landybob_v8
its on the garage option at the top of the page
mrs happy again
Re: Oil change.
which site is this then Rob (landy bob)
IanT
Post by IanT »
Thanks guys, a few good tips to keep a simple job .. simple!
scoobyv8
Post by scoobyv8 »
and if all fails, i seen a neat tool on fleabay lastnight. you remove the dizzy and fit this drive rod into its place and turn it with a drill. allowing the oil presure to build up before the engine turns. and it was only a few quid too. might have one for the toolbox i think
The refinement of modern day comfort, and the prestige of a rover V8! In the making.
landybob_v8
think he is on about the garage page on this forum tone ive got a link on my avatar there
mrs happy again
scoobyv8 wrote:and if all fails, i seen a neat tool on fleabay lastnight. you remove the dizzy and fit this drive rod into its place and turn it with a drill. allowing the oil presure to build up before the engine turns. and it was only a few quid too. might have one for the toolbox i think
Always worth having a priming stick just make sure you get the right one, Rimmer Bros sell them too.
made both of mine at work (for sd1 and early pump)
landybob_v8
i bought that one off ebay last night
:D
can scrap my super bodge old dizzy with the drive cog ground down and hammered in drill rod where the rotor arm sits
it does work well but wont fit in a tool box!
mrs happy again
sounds like a good excuse to get a bigger tool box to me :lol: a man can never have too big a tool box.
landybob_v8
it arrived today
it wont fit my drill!
its too fat
2 options
1 buy a bigger drill
2 get it on a lathe
mrs happy again
