http://www.v8tuner.co.uk/product.php?id=483
And I know cheap is normally bad but is this cheap and nasty or cheap and good for the standard cam?!:
http://cgi.ebay.co.uk/LAND-RANGE-ROVER- ... 18Q2el1247
Myth.....that depends on the overall characteristics of the cam, not just the LSA.Blown v8 wrote:it doesnt say what the lobe seperation is !
you want between 114 -116 degrees with more duration on the exhaust side if possible
too much overlap and the "charge" blows straight out of the exhaust valve
Unless they tested his engine on a dyno with every cam variation possible.....then they cant say which cam is best.Blown v8 wrote:poppycock !
B&M spent 100 of 1000s of dollars perfecting cams for there roots type blowers (which Mr. Topcat has) and low and behold. they came to the conclusion 114degree lobe centres !
a coincidence ? I dont think so !
a turbo motor requires a different cam to a blown motor !
The old adage says turbos suck !
I would rather be blown
Here you say it your self.........the cam we are talking about is a ...according to the advertisement on the given link....Blown v8 wrote:.........a turbo motor requires a different cam to a blown motor !
How can this cam working on both enginesV8 Tuner wrote:Rover V8 SUPERCHARGER or TURBO Camshaft
