New head bolts query??
I've built another 3500 engine. I'm not fitting ARP to this one as its a gentle road car only. The new head bolts look like the old style stretch bolts, but are more matt black. I'm only fitting 10 bolts and have been told to fit them 15ft/lbs, then 90 degree's, and another 90 degree's.
I did the 15ft/lbs, and then did the first 90 degree's. But getting to the first 90 degree's felt pretty tight. I've run the torque wrench over them after an hours settle time after the first 90 degree's. And they click the wrench at 68 ft/lbs. At 72 ft/lbs they will just try to move. I would only normally fit at 70 ft/lbs so I'm poop scared of trying the next 90 degree's as I reckon something will go wrong.
Or am I just being a wimp as they will stretch on the next 90 degree's??
I've tried to contact the engine builder (who I trust completely) but he's away for a while.
Not that it should make any difference, but I have had the heads skimmed and the block decked and am using comp gaskets.
Any suggestions chappies??
I'm all for leaving them at 70ft/lbs and perhaps nipping them down after its been up to full temp and gone cold again just to see if they will take anymore.
Perry
Perry
Chris
The new bolts dont have loose washers. The washer section is sort of moulded into the bottom of the bolt head as one piece.
Time to bite the bullet eh chaps??
I'll go back to the garage and try the second 90 degree's then...
I've fitted ARP studs to my 4.6 Andy. From memory they only go to 68-70 ft/lbs with ARP lube.
I've done the second 90 degree's on the 3.5 I'm building and all seems fine.
