Does anyone know if these things actually exist. I am deffo not confusing the little trigger wire resistor from the -Ve side of the coil to the over-run relay and then onto Pin No 1 in the ECU.
This is important as I have removed the Hyfire VI A from the car, tested the Mallory series 57 MBI dizzy and in-line circuit protector and also the Pro-master coil. The original coil is still in-situ but connected to the EZ trigger.
There is a Mallory part No 700 (Ballast Resistor - long rectangular, square section and white coloured ballast resistor) removed also.
I need to ensure that I am not "over-resisting" the circuit and will be replacing the Mallory kit on Sunday this coming weekend.
Mallory support is confusing in that I have all the relevant pdf files demonstrating the wiring but they depend on whether there is an in-situ ballast wire already in the wiring loom.
Driving me mental - or is that just increasing the level of "mentalness"
Need any more info - let me know and I'll do my best to provide all the info to get some help in this struggle.
Thanks all.
Doc
