Buick 300 heads on Ebay cheap
Mark
Post by Mark »
http://cgi.ebay.co.uk/Rover-V8-BUICK-30 ... dZViewItem
Not much use to me, but there are plenty of RV8 people on here :D
Mark
are the combustion chambers bigger thus lowering the compression?
Think they are T not sure by how much tho. There is also something wrong with the valve sizes the as the exhaust is small unless the buick ran smaller exhaust valves than the rover.
HairbearTE
Post by HairbearTE »
Yeah you read it right Marki, the heads in that ad have the standard size valves and the exhaust valve of a buick 300 ally head is indeed smaller that that of a rover head. That probably means that the original seats are in place which may not be compatable with leaded fuel. To be honest no-one buys buick heads and leaves them stock, the whole point is that they are a better base from which to start a performance head build-up. Yes the chambers are bigger too which could be useful if you're building a turbo motor. Gregg55 is a good person to speak to re the buick heads, he knows a great deal about them and can advise. I have a pair of these heads myself, i've stripped em, taken seats out, blasted 'em and dipped 'em! and also had them annealed ready to weld up those big old chambers. However there is some damage to my heads, slight on one head and heavier on the other. Gregg passed a pic of the damage onto another buick expert for me who says its corrosion and not to worry but others who have seen it expressed concern that it may be porosity :( Apparently this is common on these heads. Also there were two batches of castings (despite them only being available for one model year!). The earlier batch have the smooth rounded style quench pad behind the plug and the later batch have a triangular shape pad. There are also some other different casting marks but the dimensions of the heads are the same in every important respect, a good job really considering my "pair" consists of one of each type! It is said that the later batch are of a higher casting quality and this is evident in my heads. I will keep an eye on the auction though as this pair seem to be ok and may be worth a punt if the price stays low but i am slightly concerned that they have been rebuilt to stock spec! the only possible reason to do this would be to unload them more easily as "bolt ons".
Robrover
Post by Robrover »
They have 54cc combustion chambers. I welded my chambers up behind the spark plug apertures and milled 082 thou off the faces to get the combustion chambers down to 37cc so I could run a decent compression ratio on the 4.6. Fitted 1.75in inlets and 1.5in exhausts with extensive porting and flowbench development.
Given the relative scarcity of these heads and their performance potential - somewhere in between a good set of stage 4 Rover heads and the mega buck Wildcats - I'd say grab them while you can.
HairbearTE
they went for only 200quid, only one bidder! i shoulda bid but i got too many parts already cluttering up the place! someone got a fair deal there i reckon.
Return to “General Chat Area”
