Belts and Tensioners!!!!
- topcatcustom
Hi again, sorted out the manifold and the nitrous- now thinking about the blower drive belt!
Using an Eaton M112 and I have 2 reasons for thinking I should stick with the standard ribbed belt and pulleys:
1) Price is a priority! (even if a 2" toothed one would look fantastic)
2) If anything goes a bit wrong it will allow the belt to slip a little without blowing something up
Am I talking rubbish or does that sound pretty reasonable?
If I stay with the ribbed belt (I am a fabricator btw) do I need to really tighten up the belt like you do do with a fan belt or does it have to be sprung so it adjusts automatically if it expands at all?
Many thanks
Many thanks
dont tighten a ribbed belt as much as your fan belt, you will only burn out your bearings !
a sprung tensioner sounds good, but if no major manufacture has made 1 in all these years. Theres probally a good reason why !
I havent had any trouble with my tensioner, traditional is the easiest way to go ! you want to be unique go for it
- topcatcustom
kev_the_mole
no transmission belt should have a sprung tensioner. Belt can jump the pulleys by overcoming the tension of the spring. Tooth belts are 96-97% efficient, ribbed belts a little less and a well adjusted V-belt comes in as low as 92%. If you can machine the pulley blanks we can put teeth on them for you which essentially halves the price and we'll see what we can do on the belt as a V8 Forum special
It's an engine Jim.....but not as we know it
- topcatcustom
Thanks, I'l keep it in mind as I havent even mounted it on the engine yet but will definately talk to you when I get round to it, does the idler/tensioner keep it all lined up with toothed belts or does everything have to 110% perfectly lined up?!
Also any ideas on ratio's? Want the engine to last a while and it will be kept pretty standard so thinking around 7/8psi?!?!
kev_the_mole
- topcatcustom
kev_the_mole
