how easy would it be to stip the loom covers off and re wire certain parts
im guessing you could pull back the rubber covers from the connectors
like the one for the extra air valve
my valve doesnt work now and seeing as ive had the loom pulled about here there and everywhere i think ive damaged the wires
is it possible then to cut the wire at the connector solder new on and then cut and solder it at the ecu end?
or is it time for a seccond hand decent efi loom of ebay? and start again cutting and lengthening to splice into the motor again
suppose this time i could make it proper as i had to cut off the connector block for the efi to car loom and wire bits up to it could get the male connector end and do a proper job then with the car loom made properly to fit a efi loom
but if i dont have to do it i dont want to eh
efi loom
landybob_v8
- Helpful or Confused
you could easy do the cut and splice or you could buy new pins for the plugs and renew the wire completely. You will get the pins from either vehicle wiring products or most likely from Maplins. Vehicle wiring will be able to sell you new plugs as well if you wanted but they wont do the ecu plug but will do the pins.
beat you to it mate
gave Rob the details via messenger at around 8pm
landybob_v8
well happy ill solder it for now but im going to knock up a whole new loom routed properly for my engine bay with quick fast connectors to get it out should i need to
and i usually do lol im never happy with it for more than 5 minuites
or i bugger it up somehow
im slowly sorting it out but things get broken or knocked as its all getting a tad old but it was a free setup so im not bothered
put it this way it works until ive done a job then it shows up with a fault completely unconnected with the job ive done hence pulling bits back off about 5 times until i find its nothing to do with it and has been a complete coincidence
tony knows that well im never off the phone lol
v8's everywhere at least the one in the spare bedrooms gone now
mrs happy again
mrs happy again
yup had to charge my phone up yesterday
