Please help! Dead Land Rover
Sportsroof302
Hello folks,
I have been searching for advice on LPG kits and this looked like a good place.
My V8 90 (on twin SUs) wouldn't start, having been fine the day before. It has got a BRC LPG kit from about 2001 - fairly basic and probably obsolete I think, with a 'Bristol' switchover system. The RAC man was all over it for a couple of hours but couldn't solve it. I don't think there is any power getting to the coil, which in turn means the relay that halts the petrol doesn't let any through and no volts get to the petrol/lpg switch unit. And no sparks.
Has anyone come across this before or know where I can get a wiring diagram?
Any advice gratefully received.
Graham
Graham
Sportsroof302
On a simple system like that, the LPG system will piggyback onto the existing system. In principle, all that it does is to shut off the petrol supply and enable the gas supply. And in the event of the engine stalling, it will shut off the gas supply.
There will be either a wire from the -ve side of the coil going into the LPG system, or a wire wrapped around the king HT lead serving the same purpose.
The LPG system shouldn't have any way of preventing or otherwise interfering with the ignition system, so you may simply be looking at a duff fuse or similar. Check for +12V on the coil +ve when the ignition is on, and use Mr. Haynes to trace back to see where the breakage is....
Sportsroof302
Thanks Chris.
I have found what appears to be a volt-repellent wire - it is the 12v feed to the +ve side of the coil. 12v at the bulkhead end, none at the coil end. I can bypass this wire and get 12v at the coil (which also brings the lpg switchover box to life) but it still won't start.
Any other pointers? It's got newish leads/plugs/coil/rotor arm/distributor cap.
Graham
Graham
Sportsroof302
I was getting a spark earlier today and the problem wire seemed to be letting volts through. Then it stopped letting volts through again - this seems to happen when the +ve LT/amplifier wire is connected.
I have tried a different coil. I checked the petrol shut off solenoid functions. The petrol pump sounds like it's working.
Lucas gremlins...
Graham
Lucas gremlins...
Graham
Sportsroof302
