I build some performance rocker shaft. Inc Roller rockers and spacer springs are replaced with steel tube´s..
Pick.
But i just wonder can i leave the rockes shaft end spring away? I want to fit slightly thicker end washer.. Idea is same as with those steel tubes. (also slightly less fricktion.)
And I wonder also that can i fit linchpin (tube) with those rocker shaft to replace original split pin?
602148A End washer..
http://www.rimmerbros.co.uk/rimmer/rove ... ker%20Gear
