Bottom pulley crank bolt.
- ihatesissycars
How do you guys get yer bottom puley bolt done up so tight?
I had to get a big breaker bar, stick the car in 5th, handbrake on full, brakes on full, chock the wheels up and then go for it! I haven't found a torque wrench that goes up that high so i just go for it until i can't do it up any more. Even then i'm not sure its enough.
I want to get it right as my woodruff key (i've had to modify the later 60mm one to fit my early crank) isn't something i'd trust to take alot of load ref driving the pulley and associated components, oil pump and cam/valve gear. I'm gussing this is why its done up so tight to take the load of the key via the high clamping force?
landybob_v8
- Helpful or Confused
- ihatesissycars
i also do
landybob_v8
landybob_v8
big bar push it in pulses until it cracks thats what i do
get the socket to sit secure then pulse soft to kin hard then back off keep doing that until it cracks off
take the bolt off then wiggle the pulley off left to right and it'll come a bit of wd40 helps the pulley come off too
v8's everywhere at least the one in the spare bedrooms gone now
mrs happy again
mrs happy again
