Hot Alternator
Muttleys V8
Hot Alternator
Post by Muttleys V8 »
Help Please!
It always happens a week before Le Mans!
I’ve had some problems with the electrics on the car, it seemed to be the alternator, faulty diode and resistor pack, have had those changed, re fitted the alternator, BUT, with the ignition off but the battery connected, the alternator is getting very very hot.
Answers on a postcard please?
Steve
Just as a sanity check, I'd remove the big wire from the alternator and check that it still gets hot. If it is getting hot, I'd expect to see some small sparks when you remove or refit the wire.
Have you done anything else on the car
Added lights etc.
if so recheck your connections
Get it fixed and I'll see you down there a week tomorrow
Return to “Cooling Area”
