Maybe this has been raised before, but Ive seen loads of pictures of V8 engines (often competition or modified) with the plug leads cable tied in pairs. ie; touching each other. Im well aware that according to many people there can be a problem with cross arcing, hence plug wire separators.
i'm curious to know; are plug leads better quality now so cross arcing isnt a problem or is tying them together still a no no?
Steve
Plug leads & cross arcing
My Mallory and Magnecor leads can be touched together and they dont short out.
Cheers guys, its not that important cos I could use separaters but I think they look neater if tied in pairs.
Ive just bought some MSD helicore leads and with the instructions it says they must be separated particularly with cylinders 5&7 because they fire in sequence, if cross arcing occurs one of them can run lean causing damage!? But as I have seen, and you have said it never seems to be a problem.
Live dangerously, syphon fuel, smoke in bed, run with scissors
Steve,
Sounds like your making progress, I remember having a missfire problem with my 3500S which I bought new back in 1973, it went back to the dealers several times and they never completely cured it, it was obviously caused by the arcing between 5 & 7 a combination of poor quality leads and not seperating the 5 & 7 leads in the holders. but of course I didn't, and neither did the dealer know that at the time and we didn't have the benefit of the internet and boards like this one to help with problems.
Kevin
Kevin
