Alternator wiring UPDATED 25/2/07
- ihatesissycars
Hello all,
I will be fitting and wiring up my new alternator soon i hope but i'm not entirely sure of the two smaller wires and which one does what/goes where.
The big wire terminal has a B+ next to it, thats obviously the main power/charge lead. That one i know what to do with.
The first of the smaller ones has D+, this one is in the middle.
Lastly, the other small one has a W next to it.
What do the small ones do? Is one for the charging warning light?
All help is appreciated!
Gav
Gav
Last edited by ihatesissycars on Sun Feb 25, 2007 3:25 pm, edited 1 time in total.
- ihatesissycars
- ihatesissycars
- ihatesissycars
Would i be right in saying that because the cars not going to be drawing anymore power now than it was before the alternator change then the alternator won't be kicking out a higher ampage, enough to challenge the existing wiring and becuase of that the existing wiring should still be ok? Any extra electrical parts could in future be wired directly to the alternator therefore not overloading the existing wiring. Does this sound ok?
No not diameter its square (cross section area) its a standard measure of cable will be about 8mm diameter. Fair enough your not going to use anymore power but what if you get a fault in the wiring? Its up to you but if you dont and something happens you have a fire. For the sake of £4 do it right. http://www.vehicle-wiring-products.co.u ... ables.html
Should also say wiring direct from the alternator isn't a good idea either.
Hi Gav,
It does not sound ok to me, all items should be taken from the battery as that is going to be the place with the least noise. The further from the battery you take a feed the lower the voltage and higher the interferance will be.
The cable refered to has an outside od or 7.5mm rated at 110 Amps - see below
Ref. Cable. mm2. O/D Amps M.
126 126/0.40 16 7.5mm 110 £2.08
http://www.vehicle-wiring-products.co.u ... html#gen10
Maximum current draw from the alternator is when the battery is low, ie just after you've been jazzing the engine over on a cold morning. In this state the alternator is recharging the battery and maybe feeding the lights, engine coils(s) and anything else on the load. It will be putting out 10s of amps at this stage and the wire has to be rated for maximum load not typical load.
IMO it's OK to have a remote battery(in the boot) and a very low resistance cable to it from the starter motor, and use that point as a takeoff to the alternator. Normal low current wiring can be off a different feed from the battery to the main fuse. To be clear, one huge cable battery to starter/alternator, one normal cable battery to main fuse.
Kev
Kev
If you are upgrading your alternator output cable please don't forget that the same output current will also flow through the earth return from engine block to battery negative. At a minimum clean and refit the existing terminals.
I know the starter current flows though the earthing strap/cable but the alternator does it for longer generating more heat from any poor connections.
jw
jw
WITH THE EXCEPTION OF THE ECU EARTH GAV,r2d2hp wrote:Hi Gav,
I know we are on about feeds,
BUT thought would say about the ecu earth and to earth that to the engine block,
errrr didnt i put that above
