jacobs controller
jacobs controller
think this is the right place for this , ive got a jacobs progressive controller, and im using a mallory unilite and c4 coil, the wiring diagram for the controller shows a yellow wire going to a green from the coil , and red to the red wire from the coil and ballast resistor, the c4 coil doesnt have any wires coming from it, and the unilite diagrams dont show the use of a controller, any ideas as ive lost the 2nd sheet of the wiring
rich
- russell_ram
hi, i dont think i got it over to good on the post, the wiring diagram would be great if you could put that up for me, ive lost the part about the red and yellow and red and white wires and where they go, as the nos system does not work, and i want to check the wiring, thanks again
rich
hi Perry, not at the moment, i wired the nos up to go off the button and forgot the controller, but i still need the diagram for it, so as to check the wiring of it, how you doing, and i need a number 47 jet as real steel had run out of them, and i need it for the 75 and 100 shot,
theres a Ford show down there on Sunday, If I can get my car back together I will be there. The last one I went to was packed out, its only about 20mins from you, over the little bridge and behind the antiques mill? probably a good move to get there reasonably early as the little road gets busy.
Ok time to drag this old post back up, the jacobs controller doesnt seem to be working the solenoids, the solenoids are if i by pass the controller, Is there away of testing the jacobs is letting power to the solenoids, I will be going through the wiring again to see if i have a bad connection somewhere, The trigger switch and arming switch are fine and so are the solenoids, so it looks like the controller is messing about,
