The Haynes manual for the Range Rover gives the valve timing. I was looking at the supplement chapter (13), and it gives the timing for the carb engine and the EFi engine.
I noticed that the carb cam seemed to be identical to the EFi cam, but for a constant 12degree difference (I forget which one was more advanced than the other).
What difference does that 12degrees make?, and why did they do it?
Cam timing
It seems that the plot thickens. Whilst putting my engine back together, before I put the heads on, I thought it was a great opportunity to check the cam timing using a dial test indicator.
I checked that TDC on the crank pulley was right, then looked for a cam lobe that was on max duration at about TDC. I measured no. 3 inlet at being fully open at 15deg after TDC on no. 1.
A few calcs shows (assuming a 280deg cam) that the valve starts to open at 35 before TDC and closes 65 degrees after BDC. These figures match up with the carburettor camshaft settings, but I definitely fitted an EFi cam!!!
According to Mr. Haynes, the carb engine produces 126BHP, and the EFi engine produces 165BHP.
How much difference can I expect this 12 degree error to cause me??? 40BHP?
Ta,
Ta,
