Head Info Please
johnwp5bcoupe
Head Info Please
Post by johnwp5bcoupe »
Can anyone tell me if these will be hardend seats or not I have been given them to possibly go on my 1969 Coupe if I go LPG :wink: they came off a RR year unknown casting ERC 0216. I read the info on the board there is no info under the rocker shafts :( I would have to have the holes next to the exhaust outlets welded up to make them look right if I use them 8)
http://s88.photobucket.com/albums/k163/ ... t=Head.jpg
http://s88.photobucket.com/albums/k163/ ... lanket.jpg
al mackenzie
My compliments on a splendid restoration
Post by al mackenzie »
I'm afraid I can't answer your question, but I really enjoyed looking through your restoration photos and it seems only proper to offer the congratulations such a thorough job deserves. One gorgeous P5B Coupe, a credit to you, provides me with much needed inspiration to keep on with my own time-consuming P5B rebuild.
'72 Rover 3500, 6yr back-to-the-bare-Base-Unit nut & bolt resto finished in time for her 40th birthday June 2012!
johnwp5bcoupe
Hi Al thanks for the kind words it takes a long time I learnt a few trades on the way :roll: it took me longer than most because I wanted to do all the tasks 8) I hope the heads will be what I wan't but if not I will have to keep searching :roll:
I have heard conflicting comments on this subject. I've seen somewhere that all heads are OK for unleaded, but elsewhere I did see a cutoff at some point.
However, those heads are fairly recent as the holes are for emissions stuff. Therefore I would use them for unleaded.
johnwp5bcoupe
Thanks Chris it seems to be a bit of a grey area :!: I see you are not too far away from me! another mod I may do later is the ZF box as per your Sherpa 8)
You're welcome to take a look if you need to.
Like the P5B, nice motor.
johnwp5bcoupe
Thanks Chris I missed a box at our local scrapyard last month sadly he did send it for scrap :( I gather it is the best retro fit for the P5b.
