heater hose?? Serp cover/pump??
- ihatesissycars
I've come up to a problem and i'm struggling for a solution.
I've changed to a 3.9 serp front cover etc and i don't know where to put my heater hoses!
The pump hase no small inlets or outlets other than for the bottom hose.
The manifold has one thats heater hose size, this on the engine side of the thermostat so i could use that one but i've no idea where to put the other. Maybe a t junction into the bottom hose? I'm stumped!
- ihatesissycars
- ihatesissycars
Yes i've seen the metal pipes but they only direct the water to somewhere, where is that?
One goes to the manifold before the stat but its the other one? On tvr's it dissapears down the drivers side of the block but i've not found a piccie of where precisely.
goes from manifold through one metal pipe to the heater, then from the heater through the other metal pipe to the pump.
- ihatesissycars
has the water pump got a heater hose size stubb mate?
- ihatesissycars
- ihatesissycars
- ihatesissycars
nice one gav
