is "35DM8" definatly a vitess dizzy?
the one with the better advance curve than range rover dizzy?
Ralph
dizzy's
There's a few threads on the different distributor types. Also for some of the types, there's different exit holes for the vac advance:
I can't remember whether they are DM or DLM8's.
And as for your question about the curve, you really need the right curve for the engine configuration you build up (or have). How many versions there are I don't know!
Have a look at the Rimmer Bros website (V8 pages), you'll get an idea of how many variants of all the bits & pieces there were.
im sure the rangy one works better on the rangy engine,
main thing is im tryign to plan for the future, once converted i want to biuld an engine which is a bit better than vitesse, an hopefully break the 200bhp mark.
planning on probly getting a fast road piper cam kit with followers an all, an guessed a vitesse dizzy would be closer than the rangy one? im not sure yet what the std injection can cope with, but thats thinking very far ahead.
Ralph
Ralph
It is my understanding that any Lucas distributor can be used on any Rover V8 engine in any state of tune and for any application provided...
that the distributor is regraphed to meet the requirments of the engine to which it is to be fitted into.
The primary and secondary mechanical advance springs will be selected to provide the correct rate of advance for the application.
The total advance provided can be set by the adjustment stops.
On the resaon as to why the vacuum advance module is positioned differently on a distributor found in a Range Rover compared to the same type of distributor found in a car, I suspect it has to do with the design of the timing cover, and overcoming clearance problems.
Ron.
Ron.
4.6 Rover 3500 P6B
That is true. The position of the water pump on the Range Rover is much higher. They are interchangeable, but there's a much smaller amount of adjustment available if you use the car type on the 4x4 timing cover.RoverP6B wrote: On the resaon as to why the vacuum advance module is positioned differently on a distributor found in a Range Rover compared to the same type of distributor found in a car, I suspect it has to do with the design of the timing cover, and overcoming clearance problems.
Ron.
