fuel tanks/fuel pumps
Ralphh85
Post by Ralphh85 »
considering putting a mini fuel tank in front of my car,
my bro put a mini tank in his landy and was good as the fuel gauge sender worked (still being rover), which is good.
however his is on carbs so having one outlet was not a problem.
on an EFI V8, is the pump usually in the tank? or is it in the engine bay? and also is there a return pipe? if there is did any of the newer spi mini's have a return?
Ralph
With EFi, you can have the pump in the tank, or outside. I have it outside on my van:
The silver thing is the fuel filter, and the fuel pump is the black thing you can just see behind it.
And yes, EFi does need a return.
the pumps are either in the tank (usually factory) or right next to it but outside. Yes you need a return its also a good idea to have a swirl pot or you will need to keep the tank pretty full or the engine will cut on corners.
Ralphh85
Post by Ralphh85 »
where would the swirl pot be situated? guessing it would have to be before the pump??
my current engine is MPI and has the pump int he tank, as far as i know it doesnt have a swirl pot? do you not need them if pumps in the tank?
i dont have any problems atm?
Ralph
Swirl pot is generally in the tank but you can get them outside and like you say before the pump. There is a thread on here debating the merits of the external type. Some say the fuel will get too hot and some say it will be fine. Course the benefit if it being in tank is it has the rest of the fuel to cool the return. You need one because EFI moves a large amount of fuel in a circuit at pressure so the slightest uncovering of fuel and you get a big air intake. This leads to the engine cutting out or at best you get a stutter until the air is purged. Easy enough to cut and weld the tank really (once fuel is completely removed) you could either put a sump on the bottom or a cup inside and aim the return at it.
Post by CastleMGBV8 »
One of these will do the trick and save a lot of hassle and expence. Yes you need a return line and the EFI pump is fitted in after the accumalator filter with an ordinary pump feeding that from the tank.
Kevin
http://bcbroncos.com/store/product_info ... cts_id=119
Return to “General Chat Area”
