Valley gasket
Chorlton
Valley gasket
Post by Chorlton »
Put a new valley gasket on the beast yesterday before fitting the replacement manifold (Offy Dual Plane)
Had a problem with one of the brackets that hold down the valley gasket at either end.
The forward one just wont fit between the two sides of the manifold. The rear one is ok and I tried switching them but no joy.
Tried moving the manifold about a tad but still no luck.
Would it be OK to grind a little off to make it fit? Daft question I know but there could be other reasons not to?
Grind it down.
tetlow
Post by tetlow »
I had the same problem.
Had to grind one.
Worked fine.
1973 MGBGT
1975 MGB V8
I thought I could see the light at the end of the tunnel but it turns out it was a train comming!!
