hotwire system idleing badly
hello everyone im new here,just a quick question,what would make my hotwire system idle badly,its all over the place
if its just idle that is rough look for an air leak first. Grab a tin of wd40 and spray round all the joints you will hear the engine note change. If that doesnt show anything then give it a proper service it may or may not cure it but at least you will have ruled out things like plugs, cap, rotor arm and the like.
The temp-sensor! It is probably telling to the ECU that the engine is cold, thus the mixture will get rich when engine warms up!nokia_aid wrote:il take the stepper motor off tonight,it only does it when its warm too,would that point to anything else
Use a multimeter to test it. It should say about the same resistance figures than the fuel temp-sensor, when engine is cold. I just had this problem with my 3.9EFI RR -90.
Rough estimates of the resistance values to expect:
-10C 7000-11600 ohm
+20C 2100-2900 ohm
+80C 270-390 ohm
-TimoV
Diesel is for poor people.
Range Rover 3.9EFI, 1990
ok iv cleaned the stepper motor and that didnt fix it,although when i unplug the stepper motor that does,although my idle is at 2000rpm and i cant seem to get it any lower when its unplugged,
it will run at 2000rpm ok but rich and then when its warm if i plug the stepper motor back in the idle goes down but then goes irratic and it tends to cut out and die,
iv cleaned stepper motor
changed ecu/afm/temp sensor/entire plenum/injectors/fuel rail/
and im about to check for air leaks
any ideas on what to try now,
