Braided Fuel Lines.
Posted: Thu Feb 14, 2008 6:28 pm
by CastleMGBV8
Just wondered what is the best method of cutting braided fuel lines.
I was thinking of wrapping the braid with some insulating tape and cutting with a junior hacksaw, then slipping the rubber protectors over the tape, then just clamping up a usual.
Any suggestions?
Posted: Thu Feb 14, 2008 6:30 pm
by katanaman
I do it the way you have just described.
Posted: Thu Feb 14, 2008 7:33 pm
Watch this for a surprise !!!!
http://www.youtube.com/watch?v=u1J7u8sG118
Posted: Thu Feb 14, 2008 7:43 pm
by HairbearTE
Given the cost of decent braided lines allround I guess this little extravagence is just about justified! especially if you're going to build many engines.
http://store.summitracing.com/partdetai ... toview=sku
Posted: Thu Feb 14, 2008 7:45 pm
The Earls reccomendation is almost free !!!
And I find a good shifting spanner handy
Posted: Thu Feb 14, 2008 8:57 pm
by CastleMGBV8
Thanks for the replies, don't think I'm brave enough for the hammer and chisel approach, will go with my original plan as that seems to work ok.
Posted: Fri Feb 15, 2008 6:49 am
by Eliot
wrap tape around it and use a very thin cutting disk in an angle grinder.
Although i do like the chisel method.
Posted: Fri Feb 15, 2008 7:49 am
by r2d2hp
I do the same as Eliot.
Wrap masking tape round it and cut through the middle of the masking tape using those very thin cutting discs in an angle grinder.
Do the same on brake hoses
