I have a set of RHS heads with effectivly .15" over length valves.
My cam and rockers will give me .667" of lift on the inlet.
I have pro comp shaft mounted roller rocker system, I have started to put everything together and have measured up to see how close to this I am to this,
http://www.compcams.com/Technical/FAQ/V ... ometry.asp
the answer is that base circle is about half way between 1 and 2. mid lift is a little past 2 and full lift is virtually off the valve.
as far as I see it there are three ways to correct this
1/Add a set of lash caps on top of the valve stems and use a slightly shorter push rod so in theory using a different part of the arc of travel of the rocker.
2/ Shorten the pillers that suport the shafts, use slightly shorter push rods to achieve the same as above.
3/ remake the support pillers with the mounting holes that attach them to the heads off set to move the rocker arm pivots about 1mm toward the centre of the V of the engine so moving the roller tip of the rocker to more over the centre of the valve.
I supose this also leads to the question "how do I know I have the rockers at the best angle to the valves centre line to start with?" as I can't find a "correct" angle anywhere.
Many thanks in advance.
