Removing a RV8 crankshaft pulley?
Rick-Manta
Post by Rick-Manta »
This had been giving me some right grief for ages now. Basically, I have been trying to undo the crankshaft pulley bolt on my nearly stripped down 3.5 engine which is just proving impossible.
Following some advise I've had already: I've got someone to stand on the block which is laying upside down (to stop the whole block tipping over), I've jammed a wooden hammer handle in one of the crankshaft counter weights against the side of the block (to stop the crank itself turning over) and I'm using a long crack bar with all my weight trying to undo the bastard thing to no avail!
Any other ideas please, I'm really stuck?
Pocket rocket
Post by Pocket rocket »
I take that the problem is the bolt won't budge as opposed to being unable to jam the crank effectively.
Have you tried an impact air gun.
Heat on the bolt
longer extension (scaffold pole) on your breaker bar
GOOD LUCK -I thought it was only me that got stuck on things like this :D
v8alex
Post by v8alex »
There's no doubt many techniques to free stubborn bolts....
Have you tried any thread penetrant / releasing agent? I would stand the block edge on and fill the cavity in the crank pulley with PlusGas and leave it overnight then have another go.
Alternatively, take the whole lot to a friendly garage with an air impact driver
Have you got a vehicle you can bolt the engine block into to hold it?
Longer breaker bar & 3/4 drive socket set.
Also make sure you wedge the crankshaft at no's 1 & 2 to reduce the risk of bending it.
winkle
Post by winkle »
Rick,
I would definately spray some release oil (WD40 or similar) on it. use hammer and an old extension bar or steel bar and tap the end of the crankshaft bolt. Then give it some stick with an impact air gun, works for me! :D
All the best
Steve
Live dangerously, syphon fuel, smoke in bed, run with scissors
sidecar
Post by sidecar »
I knocked up a handle that I could bolt onto the damper using the pulley bolt holes. I used to old square section steel mig welded up. (Old school table legs!). The handle was a couple of feet long and can be made to hit something to stop the damper turning. (Like the floor or chassis).
Impact gun has always worked for me.
jrv8
Post by jrv8 »
Take the block to your nearest tyre depot and get them to use the wheel gun on it.
It'll come off with that for sure.
Sometimes they're a right sod to shift, but will always let go with the air impact tools.
Jim
Rick-Manta
Thanks for the replies. I don't have a impact gun and buying an air compressor is something for the future but not the nearby :)
I've soaked the thing in plusgas and WD40 but the trouble is I think with the 160 ft lb torque setting. Once I've changed the cam and timing gears, got the cover back on etc, it'll be pretty hard to torque back up by hand.
I could ask the tyre centres, lifting the engine into my boot may be difficult mind!
Thanks again, I'll keep trying.
sidecar
Post by sidecar »
Rick-Manta wrote:Thanks for the replies. I don't have a impact gun and buying an air compressor is something for the future but not the nearby :)
A good torque wrench will allow you to torque it up but you will have to lean on it pretty hard! (That's why I made a holder for my damper)
