lemax
v8man
lemax
Post by v8man »
:D any one seen one of this ??
Post by ian.stewart »
Its a LSD, Whats it out of??
v8man
Post by v8man »
:D yes we figure that lol
:D i just wanted a bit more info on it :D how strong it is etc
at the moment is on my 4.8 litre John Eales tr8 on a t5 and 3.45 rear end :D
The LSD wont be a problem in its durability, Do you know what make it is, it dosent look like a Quaife, it could be a ZF, may even be a factory option fitted to some V8 Sherpas, somtimes found in Emergency service vehicals, From memory the axle is very tough, it may even be a decendant of the Austin Westminister axle which WAS the axle to have if you were a V8 superstox racer, and many drag racers used them too. and the LSD makes it even less likely to break as it shares the load between the Halfshafts.
v8man
Post by v8man »
:D cheers for that :D
only thing i see on it is LEMAX ?? + a number starting with 3
