Which clutch
digger782
Which clutch
Post by digger782 »
Help needed to identify the clutch I need to fit my rover V8 to my lt77 gearbox?
The thing is that the gearbox and bell housing are from a Sherpa but my motor factors don’t know which clutch kit I need. I know it is 23 spline but they keep quoting 9.5” and 224 mm what does that mean?
Would a standard kit from a SD1 fit please help as I want to put the box in over the hols
Many thanks in advance
:shock:
Post by ian.stewart »
the clutch you need will be from a SDI assuming the flywheel you are using is from a SDI and not from a RangeRover, all the splines are common accross the LT77 2wd boxes
