Right I have come to the conclusion that my 3.9Efi Hotwire is drastically over fueling.
So much so that not only is it fouling the plugs on tick over it also has so much fuel it runs down the bores and contaminates the oil and my oil level rises constantly.
So here comes the question.
What tells the motor to come off choke? There must be a temperature control sensor that cuts that changes the mixture.
Or am I talking utter rot and should be giving up and putting it all back to carbs?
Adi
Another maybe daft question
Is it in "limp home" mode?
If you run diagnostics on it fine - if not
Disconnect battery for 30 seconds
Reconnect Battery
Fire her up - it clears the ECU memory
But then something normally triggers it for it to go into limp mode so you may cure it only for it to reappear - that said it's easy to knock off the list!
Reconnect Battery
