Strong Bottom End RV8 Block
Wotland
Post by Wotland »
Hello,
On old forum I had posted an topic about alloy girdle plate for early Rover V8.
During this summer, I have made one girdle plate in 20mm tickness 6014 Aircraft Grade Aluminium Sheet.
sidecar
Post by sidecar »
That's a nice bit of kit!
I noticed that your block is also cross drilled, what are you planning to run this engine on, nitroglycerene? :D :D
Regards,
Pete
sidecar wrote: I noticed that your block is also cross drilled, what are you planning to run this engine on, nitroglycerene? :D :D
I wondered that - is this going to be the first 1000bhp RV8? :racing
Wotland
Post by Wotland »
:lol:
It was for my P76 project but opted for other option.
Two girlde plates waren made : one for me and the other for an friend for an hillclimbing RV8 powered car.
chodjinn
Post by chodjinn »
Did you sell one of these on ebay relatively recently??
Very impressive piece of machining that mate. Will there be any more produced, because I may be tempted hehe!!!!
Wotland
Post by Wotland »
Hello Chodijnn,
Thank for compliment. Yes I have listed mine on Ebay due some changements in my project.
Alloy plate is very expensive (around 100GBP) and JED main studs kit also expensive. I have payed 127GBP with VAt just for 10 custom studs :( . (no nut, washer and spacer). ARP extra long main stud kit would have been less expensive.
I am not in Europe at this moment, back only in January.
If you are always interested by alloy girdle plate, contact me at this time. I can made one for you.
Cheer.
Dimitri
