Hello All,
Can anyone help me ? I've just fitted a 3.5 SD1 V8 into a 1975 MGB, I have an electronic dizzy with the small box on the side (Lucas 35DLM8 I think). I'm trying to wire up the ignition, I need some sort of wiring diagram to go from my old MGB wiring to the electronic V8 set up. I think I have the alternator sorted just the coil and dizzy not sure about?. I'm at least 1 wire short to the dizzy? Do I need a ballast resistor?
If you could help me I would really appreciate it.
Many thanks Adam
Dizzy and coil wiring
MGB V8
jrv8
Hi Adam,
The outermost one connects to the coil (-)
The inner one connects to the coil (+)
+12v should be connected to the coil (+) through the ignition switch, and the pick up wire from the rev counter should be connected to the coil (-)
No ballast resistor required, but make sure that you're using a coil suitable for electronic ignition.
Regards
Jim
Regards
Jim
