Holley 390 to Offy 360
Well not being able to afford the Edelbrock 500 bits and bobs I have elected to go the above route. Hmm!! Now I need to find the adapter plate that mates the two together, having got the carb and inlet manifold sorted. Any suggestions, anyone as to where I might get one?
Also does nayone have any thoughts on their experience of this setup on their 3.5 or recommendations?
Thanks for any help.
Re: Holley 390 to Offy 360
You can buy ready made adaptors from Summit, to match the carb to the manifold. I made one myself from 1/2" as I'm a masochist like that .sean wrote:Well not being able to afford the Edelbrock 500 bits and bobs I have elected to go the above route. Hmm!! Now I need to find the adapter plate that mates the two together, having got the carb and inlet manifold sorted. Any suggestions, anyone as to where I might get one?
- Pocket rocket
Mine has two oval slots and not like yours. The ebay link for it is.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... otohosting[/url]
- Pocket rocket
And strangely it's a couple of quid cheaper direct from his website
http://www.v8tuner.co.uk/product.php?id=114
Yeah, I saw the one from V8 Tuner but looking at it I just don't think the holes are far enough apart for the Holley and the Offy. Besides I had actually mailed Paul at V8 tuner and he said it would need to come from Offenhauser, for which I haven't yet found a proper site.
I have a feeling that I may be in a similar position to Paul B.
For what it is worth the mounting holes for the Holley are approx 194mm diagonally and 137nn for the Offy carb mounting holes. The pic of the V8 tuner one certainly doesn't look that far apart.
Agreed! Weird! One would have though it was simple.
I wont even mention trying to get a rebuid kit for the exact carb number. How much can a 390 cfm 4160 Holley really differ?
http://www.offyparts.com/ its that simple..sean wrote:.... it would need to come from Offenhauser, for which I haven't yet found a proper site.
Next option, you only need the adapterplate to fit the holley pattern carb on a Offy patern intake. You could take a normal 1" Holley Alloy carb spacer, drill the extra holes for the Offy patern and here's your home made Offy carb adapter. Ohh forgot, you'll need Allan bolds to fit the adapter cause the'll sit in the adapter.
[/img]
