Clutch flexy?
Chorlton
Clutch flexy?
Post by Chorlton »
Spent yesterday sorting the brake pipes and flexy's out, then suddenly remembered the clutch.
I have the master and slave and its obvious there must be a flexy in there.
Ive searched Rimmers and Real Steel but cant find any part number or reference.
What do you blokes use?
Both mine are auto's :D
Chorlton
Post by Chorlton »
Auto's ???
You mean brake hoses? the fitting on the master and slave look a bit too big for brake hoses.
jrv8
Post by jrv8 »
If you, measure the length required, and the threads being used, we can make you up a braided pipe to suit. (or a combination of braided flexi pipe and steel pipe)
These are bigger diameter than the standard brake hose.
Regards
Jim
Where are you based Chorlton?
If you are not near Jim, you could try Think Automotive in Hounslow, or Flexible hose supplies in Slough or any Pirtek branch.
If you look through the Pirtek catalogue, they sell a load of brake and nitrous stuff. But most of the guys on the counters dont know what it is.
