There wasn't any as std, but would you use some? I'm inclined to, don't want to repeat this particular job (fuel tank in/out) if poss...
Any suggestions for a fuel-proof sealant if so?
Bill
Fuel fittings: sealant
Re: Fuel fittings: sealant
If it is on taper threads, use a couple of wraps of PTFE tape, but go sparingly, and only where the threads meet, not all over the fitting, else you might lose bits inside the fuel system.Alley Kat wrote:There wasn't any as std, but would you use some? I'm inclined to, don't want to repeat this particular job (fuel tank in/out) if poss...
Bill
I've seen guys use twenty wraps of the stuff, and most of it is left outside the joint, or inside.....
Don't use it on parallel threads, as it is useless then.
