Rocker cover baffles
winkle
Post by winkle »
Hi, Ive finally finished fitting yella terras and now realise that there is very little clearance between them and the standard rocker covers. I was aware that this might be the case.
Is there any reason why I cant leave out the baffles in the rocker covers?
I think if I double up the cork gaskets or fit the newer rubber type I will get enough clearance from the rockers providing I leave out the baffles :?
Live dangerously, syphon fuel, smoke in bed, run with scissors
you can leave them out but you might find a lot of oil ends up coming out the breathers.
