Oil pump/filter query
simon
Post by simon »
On my rover engine I have an oil cooler fitted. Just above the take offs for the oil cooler is a hose which feeds oil under pressure to the turbos fitted to the engine (see pic, nearest hose) I'm removing the turbos and want to know what to do with this oil feed. As it's under pressure, I presume I cant just blank it off. Is it a part that can be removed? (sorry, rover virgin here)
Simon
if its the connection nearest at the bottom then yes you just blank it off.
