HIya all,
Well this must be the last of the my problems i've had to solve to get this monster running.
Flapper efi fuel pressure set at 36psi with engine not running.
When engine runs with vacuum to FSI pressure regulator disconnected fuel pressure is constant 36psi.
Engine runs sweet & rock steady.
When engine runs with vacuum to FSI pressure regulator connected then fuel pressure drops to 24psi.
Engine runs very lumpy & stalls.
Is my power boost valve suspect?
What should the vacuum pipe connected fuel pressure be at idle with a power boost valve?
36 or 26psi?
Thanks for any help
scott richmond
fuel pressure problem - runs lumpy
- Seight-V8
- Seight-V8
ramon alban
Re: fuel pressure problem - runs lumpy
26psi at idle and on overrun = hi vacuumSeight-V8 wrote: What should the vacuum pipe connected fuel pressure be at idle with a power boost valve?
36 or 26psi?
36psi at full throttle = lo vacuum
Or anywhere in between depending up engine load (manifold vacuum)
- Seight-V8
hello again,
Well went straight through the mot, no problems.
But while it was there ask the mechanic to test the col levels.
And on idle co level was only 0.25%, so running lean on idle.
Looks like i need to increase the co level abit, this might help my lumpyness also.
Car ran great though, blew some cobbwebbs out on the way back, cannot complain about the amount of power available.
All the hard work was worth it in the end, i now have a smile again.
thanks for everyones help.
scott
scott
