Fuel pump
Fuel pump
Hi, can someone advise me on what fuel pump setup I will need when fitting a supercharger,ie how do you vary the fuel pressure to cope with the air pressure , is there any good books?any info appreciated. regards David.
What engine etc?
Are you running EFI or carbs?
If the former, get an EFI fuel pump and a fuel pressure regulator. If its e.g. a Rover V8 with Hotwire injection, the standard pressure regulator is situated at the end of the fuel rail; connect the vaccuum connection to the plenum.
there ar a few good books but I dont know what they are, I'm sure someone will chime in with info soon
Re: fuel pump
If it is a suck through carb application I reckon you can just use the normal type pump, making sure you have enough pressure/volume available to maintain fuel pressure under full acceleration.Marsho wrote:Hi, sorry forgot to add running edelbrock carb on 4.6 rover v8 thanks David.
