John Eales crank damper, oil seal journal eccentricity
Bart
Post by Bart »
Hi all,
I am building a 5L Wildcat engine for my Chimaera. I was having problems with valve gear and springs. Got that sorted now.
Just one problem after another with this build though, which I expect, but some are problems that should not occur.
Long version --
I bought a performance crank damper from John Eales. The rubber in the old damper was starting to show signs of degradation. The JE item is slightly larger than the standard item, so I had to slightly relieve the timing pointer a bit to get it to clear. It's an interim serp front cover.
I had timing marks machined on the damper, and a hole for a roll pin for the pulley.
I fitted a trigger wheel this weekend. I have had to space it off the damper a bit, so I had a spacer machined to fit between the damper and trigger wheel. The trigger wheel no longer locates on the damper in this configuration, so I had an alignment tool made that centres on the oil seal journal, and welded the trigger wheel to the spacer. Worked well, were it not for for the following.
I was measuring up to make a bracket for the sensor today, and I noticed that the trigger wheel has runout, despite my alignment collar. Upon investigation...
Short version --
... it turns out that the oil seal journal on the JE damper has 17 thou of run out. Runout of the outer part of the damper is about 2 thou, so the bore is concentric with the damper, but the seal journal has been machined off centre.
My question is, how much run out on the oil seal journal is permissible? Close to half a mm seems way too much to me.
Re: John Eales crank damper, oil seal journal eccentricity
Are you sure you have that amount of run-out? How are you measuring it?
Assuming that is total indicated reading hence double the amount of eccentricity.
I don't know what value will give you a problem but if I'd bought a, presumably expensive, new item and found that much error in it I would not be happy. I would take it up with the supplied first asking what their runout specification is (before telling them what you have - I have trust issues!).
The fact that the oil seal being compliant will allow for 'some' runout does not make an out of spec' item acceptable.
Seal runout allowance greatly depends on seal type - and shaft speeds.
This might give you some ideas:
https://www.skf.com/uk/products/industr ... cification
But 17thou - nearly 0.5mm for me, is way too much.
Even it is 'works' at first - it will reduce its service life.
