Hot wire AFM
Beastmaster
Hot wire AFM
Post by Beastmaster »
I need an Afm for my 95 3.9, do i need the specific unit or are there interchangeable parts,im sure i read about someone using a Jag unit.........unless anyone has one they dont want?
People used Jag flapper AFMs on Rover flapper EFis because it was larger. If you've got a 3.9, then that doesn't apply because it's hotwire.
Beastmaster
Ah thanks for that Chris,will keep scouring the breakers,can you confirm its the 3AM afm that i require 3.9 hotwire 95 disco (softdash)?
