I have a kit car running a rover 3.5 V8 wIth a holley carb, the engine is a 90's discovery engine originally equipped with a set of SU's
I am really struggling to get it to run well at all
I have reset the holley and changed the fuel pump as when i got the car it just didn't seem to want to keep running and stank of fuel (Running crazy rich). Also the rev counter would go erratic when the car was rev'd and didn't look to read correctly.
It then stopped starting....
So I pulled all the spark plugs out, cleaned them (they ere black), reset the holley to starting position mixture and bang it started but wont idle unless i keep the throttle in a little and have it idling around 1000 - 1100 rpm (900 ish when warm). What should it idle at?
However when reved the rev counter is erratic and it sounds very rough.
I then tried to get my strobe light with integrated tacho on it, but I get intermittent reading on cylinder one, give a reading then nothing same with actual strobe its intermittent.
I tried my other strobe light and that give me a light (it has no tacho) but it seemed a bit hit and miss too.
Also I cant find any timing marks on the bottom pulley
Should I replace the coil, leads, plugs, cap and rotor arm? OR should I just rip it out
Any advice would defiantly be welcome as I am scratching my head a little.
Scott
